I have a 1995 Four Winds fifth wheel with a super slide on it. For the last few trips, the slide has slid out about 5" while traveling. I had to pull over and slide it back in, only to notice it would again be out just a bit down the road. I can't figure out why the hydraulics are leaking and not holding the slide in. I can let it in all the way and as I release the button, I can hear the pressure relieving and see the slide easing out just a little.
Any suggestions? The manual valve is closed tight.
97 Dodge 2500 Ext Cab 4X4 CTD with Goerend Transmission mod.(GVWR 8800lbs, or 4000 Kg)
95 Four Winds Fifth Wheel
99 Toyota Fourrunner V6
