downtheroad wrote:
DRM796 wrote:
Thanks downtheroad,. Shouldn't my battery have a full charge if it has been plugged I since the end of August?
Most definitely they should...
I was just taking a shot at it, but unless you have bad batts, I doubt that my suggestion is your problem.
Downthe road, I believe you were correct. The next day I notice that one of the nuts on a terminal on the motor was loose. Also was checking the circuit breakers connected to the battery and I think one of them was tripped.
Went on trip the past few days and the slide outs ran properly. So even though I was plugged into to land power I don't think the battery was getting charged. Just wanted to let you know.
Thanks again.
