time2roll
Apr 03, 2016Nomad
If you can rotate the hitch past the nylon block by hand with moderate effort then you are good to go.
If it barely hits, too loose. If it takes a strong effort then it is too tight. Yes you may need to tighten a few times as it works in.
Also read pg 11 of the manual
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 16, 2025
