Gray_Fox's avatar
Gray_Fox
Springs
When I had new springs put on the 5th/W Some of you guys talked
about (wet bolts) is that a bolt you can grease? if so that's what they
put on.
  • You will need to experiment with how much weight to remove from each spring. The goal is to see grease flow from both ends but depending on how much weight is hanging it may only come out one side.
  • Gray Fox wrote:
    Yes they greased them but I will grease them again before we go out
    again.
    Let the tires hang when greasing.
  • Yes they greased them but I will grease them again before we go out
    again.
  • If you had to ask, that means you haven't greased them yet. Do it often, there are no seals to keep the grease in.
    put on.
    thats a good addition.... hopefully they did heavy duty shackles while doing it..
    Most kits include the heavy shackles.
    Lyle
  • yes. has a 'nipple' on the end of the bolt.
    NOTE: these bolt do crack/break so periodically check them.
