Apr-07-2013 04:40 PM
Jun-22-2013 07:01 PM
Jimf1234 wrote:
My hydraulic landing is very sturdy but the rear of the camper with 4 bunks in 2 slides moves quite a bit when the kids are moving. I realize they are 4' beyond the camper but does anyone recommend a set for the rear? I'm almost thinking about adding more stabilizers to the rear.
Jun-22-2013 02:42 PM
Jun-21-2013 09:15 PM
Jun-21-2013 07:14 PM
Jun-21-2013 06:44 PM
mbrule wrote:
I am seriously considering either the JT Strongarms or the Steadyfast system. Has anybody installed either themselves? If so, how was the job?
Does anybody have experience with both, I like the way the Strongarms attach to both jack and stabilizers (I like symmetry) and it seems this would work better.
The Steady fast have things to tighten, probably and easier install, but only attach to 1 jack and stabilizer, leading me to believe that they would not work as well?
Opinions??????????
My fiver is a 32 ft Kountry Star 11k dry 15k GVW if that matters
Thanks!
Jun-21-2013 04:10 PM
Jun-21-2013 03:37 PM
Jun-21-2013 03:24 PM
mbrule wrote:Mine had that really hard plastic that was tough to cut but would distort across the bottom and looked terrible. I patched it with some black automotive firewall sealant.Atom Ant wrote:
I installed the front and rear JT Stabs on our last rig. It took me the better part of a day. It's all pretty straight forward. Each unit is a little different, but to access the rear crossmember to verify I was hitting steel instead of a tank required me to cut a slit in that belly material to access it and then install a patch over the belly material to reseal it.
Not to derail the stabilizer discussion... But, you have brought up another point of interest to me. How does one patch the belly material? On my last trailer I had to make some cuts (and may be this one too t install the stabilizers )due to a water mishap, and never did find a good way to patch the cuts.
Thanks everyone!!!
Jun-21-2013 02:19 PM
Jun-21-2013 08:26 AM
Jun-21-2013 07:41 AM
Jun-21-2013 07:20 AM
Jun-21-2013 06:12 AM
Jun-21-2013 04:47 AM
