- Old-BiscuitExplorer IIIWhere are you plugged in...CG pedestal, at home etc?
Need to get incoming power..both legs (should be 120V AC +/- 10% on each leg)
Check neutral......should be '0' if balanced
Outlet testing - reddwarExplorerCan't find it in my 6" HH book. So looked progressive industries up on line can't find PS 5. P stands for Previous Error Code: & E-5 Line 2 Voltage High (Line voltage above 132.
So will call tomorrow but will leave unplugged today as I think we are getting spikes over 132V.
If anyone knows for sure what is going on for sure would appreciate help
Thanks
red - Old-BiscuitExplorer IIIProgressive Industries Error code
E-5 Line 2 Voltage High (Line voltage above 132 volts)
That suggests an imbalance on one of the power legs and device is tripping incoming power as designed
You can download manual for your 50A device.......HERE
Left hand column......pick your device - reddwarExplorerIt is built in 50 Amp, progressive industries.
red - vic46ExplorerWhat does the operator's manual describe the error code PS 5 as?
Make and model of the device would be useful.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 13, 2025
