dedubExplorerApr 24, 2013Swapping tiresI need to swap tires around on my 5er. Can you jack under the U-bolts one-by-one and get away with it or is it bad JuJu?
Me_AgainExplorer IIIApr 25, 2013U bolt is better than directly on the axle. I flipped my axles, so old spring pad makes a perfect jacking point. Chris
Related ContentRam CP3 swapCenter Console SwapPrevost engine swap possible?DVD/Entertainment Unit Swap?tires, tires, tires
