nvreloader
Oct 21, 2013Explorer
SxS Heights
Wife wants a sxs, been thinking of the new Honda 700-4place.
The trouble starts when loading the sxs into the DF TH, max clearance height under the bottom double bunk is 72-1/2". No sxs I have looked at will go under the bunks.
As an Idea,
I was thinking of cutting the roll bars/cage off, then inserting an steel pipe insert into the OEM pipe, at the cutoff section, either welded or pinned.
Then add the cutoff section of roll cage/bars, over these inserts after unloading the sxs and securing with lock pins. This way, I could carry the sxs with no problems in the clearance under the bunks.
Anyone else have this problem??
Tia,
Don
As an Idea,
Tia,
Don
