jmtandem
Dec 28, 2016Explorer II
AH HA!...ok so when the spring compresses it gets longer... ok,I get it. That makes total sense.. I got the upgrade idea from Barney..(Thanks again) that is why I stopped right where I did. But I did not still quite understand it but now I do. I'm ordering the EZ- flex which has the wet bolts and bronze bushings. Weather here has been cruddy to..no fun working outside at the moment.. but the upgrade is coming. Thank you all. One small edit...I think I would rather have the zerks facing the inside rather than towards the tires. Just my opinion
What I did was to make sure the zerks work before installing. The instructions suggest either a 3 or 9 o'clock position and some times it can be a little hard to get the grease in after installation. They can be installed either facing inward to the inside of the coach or outward. You will need a drift (or use a bolt with the threads removed) and possibly a handheld press to get the old ones out and get the new ones in.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 13, 2025
