Super_Dave wrote:
This is my thermostat. It reminds me of being a kid and not getting a joystick to make the game do what I want. The "touch" feature doesn't respond friendly when trying to set temps or switch between heat and cool.
I had the same issues with this thermostat, so I contacted Dometic via the support request function on their website. Here is the exact response from them:
"Thanks for choosing Dometic. We typically have this issue with this product. There is a way you can temporarily fix this issue by removing the face of the tstat, ad there is 3 pin points with foam in the inside. Gently remove them, and place them on a table until they puff back up, and gently place them back. To change from Celsius to F’, you will need to press both the up, and down button to change that. In the meantime, I will send you a new face as I have your shipping info via email. Have a good day."
