ttempletonExplorerOct 17, 2014Thermostat??2006 Jayco Designer 36Rlts. Thermostat on back side wall near big window. Can't figure out what it is for?? BE kind.
3 RepliesReplies sorted by NewestSort ByMost LikedOldestNewestSea_SixExplorerOct 18, 2014Could be for the propane heater.ReneeGExplorerOct 17, 2014donn0128 wrote:Fantastic fan?You are probably right! We have two Fantastic Fans and two thermostats for them, which is correct because you set the temp and the fans will run till the inside temp is reached.donn0128Explorer IIOct 17, 2014Fantastic fan?
Related ContentThermostat not getting 12vDometic digital thermostatDomestic thermostat ccc2Thermostat issuesNew thermostat question?
