Timbrens
Veebyes
Every year I do an upgrade here or there for the truck or trailer. As the truck is starting to get long in the tooth I thought it time to give the rear springs a little support so I have ordered a set of Timbrens.
The truck is a DRW. The 5er has a listed dry weight of 11,500#. All loaded up full of water, 100gal, I guess I am pretty close to 13,000# if not over.
The Timbrens can be installed with or without extra rubber spacers. Are they likely to be needed?
2007 Alpenlite 34RLR
19 REPLIES 19
F-TROUP
I've had a set on my 2001 for for 15 years still going strong and works great. Replaces axle rubber bump stop and sits 1" above my axle.
Lwiddis
Supporting, read that as bandaids for the old springs, or buying new springs is an easy question for me. Your difficulty is?
djousma
according to the Timbren install guide, you want about a 1/2" or so of clearance between the bottom rubber and the stop. If its touching unloaded, you wont like the ride...
Dave
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
2017 Forest River Cardinal 3850RL
donn0128
Im guessing you should have done it right and bought new rear leaf springs. I think you would be happier.
ugeesta
It might depend on your pin weight. The pin on my trailer is about 2,300lbs and drops the bumper around 2”. I just bought a set and going to put them on this weekend. For $200, it couldn’t hurt.
2018 GMC Seirra 3500 Denali SRW
2018 Jayco Talon 313t
2019 Polaris XP1000 Trail and Rocks edition
2016 Yamaha Grizzly EPS
1 wife & 5 cats
