Jan-26-2014 07:31 PM
Feb-06-2014 03:41 PM
JIMNLIN wrote:
At one time all 1/2 ton trucks came with 15" tires so we had many different sizes and load ranges to choose from for our trailers. Not many 15" LT tires are mfg'd anymore.
My 28' 11200 lb 5er came with ST225/75-15 D Marathons on 5200 lb axles .
I won't use any brand ST tires on heavy trailers so I upgraded to a 16" LT 215/85-16 E at 2680 lbs capacity. I now have around 45k miles on the second set after running the 1st set for seven years and 55k miles. I've had zero problems with them.
A good experienced tire dealer can check your trailer out if the taller 16" tires and wheels will have proper clearance. Dexter says 2 3/4" at the top of the wheel well and 1" between the tires on std leaf spring suspensions will work.
Feb-06-2014 12:40 PM
laknox wrote:57 Panhead wrote:
If I couldn't put LT tires on I would go with Maxxis ST tires. I have run them before and they were excellent tires.
Steve
x2 on the Maxxis.
Lyle
Feb-05-2014 06:13 PM
Feb-05-2014 05:35 PM
Feb-01-2014 06:41 AM
Jan-28-2014 01:41 PM
Jan-28-2014 08:21 AM
Jan-28-2014 06:24 AM
Steve
Jan-27-2014 04:22 AM
Jan-27-2014 12:14 AM
Jan-26-2014 08:21 PM
Jan-26-2014 08:11 PM
Jan-26-2014 08:06 PM
idtrout1 wrote:
Within the next 3 months I will be replacing the tires on my 5th wheel (28'). I have read many of the posts on tires and recommendations but could not find an answer to my question. My tires on the trailer are 225 15" with an 8 ply rating, I thought about putting LT tires on but can not find any LT tire in a 15" with a rating of 8 or 10 ply. So now I'm back to looking at trailer tires and selection seems limited in a 15". So any suggestions or experiences you have had running 15" tires.
Jan-26-2014 07:42 PM
