โJun-16-2013 03:01 PM
โJun-16-2013 08:13 PM
Me Again wrote:FastEagle wrote:Me Again wrote:FastEagle wrote:Me Again wrote:
Calvin. Yes I just park the trailer on each end and put tire covers on the sunny side. It is the Kiss system! Chris
So, that is that why you disrespect remarks about better maintenance and safety?
FE
Please explain what is safe about all your ST tire failures! How has it been working for you?
Chris
What does that have to do with anything I said in my original post about tire conditioning when parked for long periods of time?
FE
Except you seem to promote the product all the time like someone pays you to do that! Nothing has changed in years except your approach now wrapped in government documents and safety talk!
Chris
โJun-16-2013 08:06 PM
โJun-16-2013 07:49 PM
FE
Chris
FE
โJun-16-2013 07:41 PM
FE
Chris
โJun-16-2013 07:38 PM
Atom Ant wrote:FastEagle wrote:Or......
When the RV trailer is required to set in one place for extended periods, the owner should try and to reposition (rotate) the tires 180 degrees every 90 days - or more often - if possible. Tire manufacturers use a lot of chemicals to help prevent ozone damage, aging and weather checking - just to name a few. Over long periods of time those chemicals will migrate to the bottom of the tire leaving all areas above them unprotected. Our cars, trucks, etc. are not normally idle for long periods and do not suffer from the lack of protection.
Another beneficial safety precaution would be to provide a barrier between the surface the tire is parked on and the tire. Over long periods of inactivity water can permeate into the tire treads and decay them along with the tires innerliner and maybe even the carcass.
FastEagle
Just don't buy ST tires.
I don't have time to rotate my LT tires 180 degrees every 90 days, so I rotate them 360 degrees thousands of times every summer. It has worked so far.
โJun-16-2013 07:30 PM
FE
โJun-16-2013 07:19 PM
FastEagle
โJun-16-2013 07:10 PM
โJun-16-2013 07:07 PM
donn0128 wrote:
WOW! Now we need to rotate our ST tires so they wont explode. That's a new excuse for poor quality junk from FE
โJun-16-2013 07:06 PM
โJun-16-2013 07:00 PM
Me Again wrote:
Hmmm! My LT tires sit for months on end in the summer in the NW and the winter in Arizona and do not have problems! Just maybe it is cheap tires verses good quality tires? Chris
โJun-16-2013 06:44 PM
โJun-16-2013 06:03 PM
โJun-16-2013 05:52 PM
