Tire PSI stamp
sunrae
We are looking to buy new tires for the 5er I remember someone talking about the rim being stamped with the max psi but I can't remember where it is stamped is it on the back side of the rim or on the inside of the rim so tire removal would be necessary to read the stamp. Thanks
12 REPLIES 12
sunrae
thanks everyone for the reply's yesterday was a rain day so no tire work was done. I will up date you when I do the tire's Wife's birthday this weekend needless to say I will be busy :B
laknox
I checked my Al rims before upgrading to E tires and found "max 80 psi" stamped on the back side. No load info that I could see. YMMV...
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
Garyl53
I currently have GY Marathons LRE run at 80 psi. I wanted to know what the wheels were rated at for the future. If a 3750# stamp means the current 16" steel wheels can handle the 110 psi LRG Sailuns then that becomes an option for me down the road.
Garyl53
Just me, wife and 2 small dogs
2011 F250 CCSB 6.7L PSD SRW 4x4 Camper/Plow/FX packages: Andersen Hitch, AirLift 5000 Bags, Bilstein 5100s
2017 Redwood 36RL
Cummins12V98
I would think most aluminum 16" wheels will handle a "G" tire.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
fla-gypsy
Mine are stamped with the max weight (2600lbs) but not max inflation. As you can see this appears to be more common than previously stated.
fj12ryder
Mine are stamped with max load, not max pressure.
Howard and Peggy
"Don't Panic"
Old-Biscuit
Garyl53 wrote:
Mine are stamped with the max load 3750 lbs. but so far haven't been able to find the max pressure. Are they all stamped with max pressure also?
3750# corresponds to 110 PSI
OP........
What is the MAX Tire PSI on current tries?
Your wheels will be rated for at least that
What tires are you switching to?
Garyl53
Garyl53
2017 Redwood 36RL
fj12ryder
Mine are stamped on the outside of the wheel, on the away side of the wheel. If you don't take the wheel off the trailer you'd have to crawl underneath to see it. But no need to remove the tire.
This is on a 2010 Fuzion.
Howard and Peggy
"Don't Panic"
phillyg
The stamp could be anywhere on the wheel as there appears to be no consistency by the wheel mfgrs.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
sunrae
thanks for the reply I was leaning that way I will find out later today when I start to change tires Happy camping
MFL
Nomad II
Nomad II
I think most will be stamped on the inside, requiring removal to verify pressure. I have heard of some being marked on the backside, so worth a look.
Jerry
