Jun-19-2019 02:34 PM
Jun-22-2019 05:05 PM
buc1980 wrote:
I think the GY 614 blow up tire is when they introduced back in 2005 but is 2019 and they stil blow.I was one of the pioneers at that time and I was very upset about blow 3 of mine blow.I replace them with Michelin Rib with the same results.Finally I went Sailun way and now I don't have any more problems that was back in 2015.
Jun-22-2019 04:57 PM
Cummins12V98 wrote:
Still does NOT determine if it was the tires fault or road hazard. Tire that young should have been sent to GY. Monitored tire was fine right up to blowing. What does that suggest???
Jun-22-2019 03:33 PM
Jun-22-2019 03:05 PM
Jun-22-2019 02:44 PM
Jun-22-2019 02:23 PM
Jun-22-2019 11:14 AM
Jun-22-2019 08:11 AM
Jun-21-2019 11:46 AM
B.O. Plenty wrote:N-Trouble wrote:I agree 100%. The ST tires that came off my last rig were like bicycle tires compared to the Michelin Ribs that replaced them. If they made a LT tire that was in the load range I need, I would have them again in a heartbeat.TXiceman wrote:
LT tires generally have more flexible sidewalls than trailer tires. Also, on an LT, check the load rating.
Ken
^^THIS^^ is so UNTRUE and what the ST tire industry has brainwashed consumers with.
When I had STs pulled off my 5th and replaced with Bridgestone Duravis R250s the sidewalls on them is easily 2x them crappy China Bombs. There is absolutey no comparison between these tires. Dont believe everything you read or hear. See for yourself...
B.O.
Jun-21-2019 11:38 AM
JIMNLIN wrote:
Lyle....From what I can find out from Bridgestone 1-800 tech line the Duravis R250 has been discontinued and replaced with the new R238. Same all steel ply carcass ribbed type tread like the R250 but has a bit more siping in the tread.
Some large dealers may have the R250 in their warehouse.
Jun-21-2019 07:21 AM
Cummins12V98 wrote:
Two years and 5 months on the market with no doubt thousands sold and not a single tire FAILURE that I have heard of and I frequent 7 sites. If that is not enough to give a thumbs up you simply don’t like GY. That’s fine but at least be honest.
Jun-20-2019 06:04 PM
Jun-20-2019 04:13 PM
Jun-20-2019 04:02 PM
Jun-20-2019 12:29 PM
cummins2014 wrote:twodownzero wrote:
I'm happy with my GY endurance tires so far. Had them since January. I used to only use LT tires, but these are doing the job.
So far, six months , not much else too say. Come back in 4-6 years, and some miles , lets see how they are doing then.
