Tow Vehicle Preferences
cemmett
We are carefully planning our investments for a fifth wheel and tow vehicle. We have had some experience with Ram 3500 dually, diesel and have read good reports on their performance. We see a lot of GM products and Fords towing the larger fivers, which is what we are considering. We are also paying attention to rear end ratios and have been told that 4.73 is about the right ones for towing. So, the question is what advice, pro and con, will be helpful? The seasoned RVers (you guys) can offer the best firsthand input. Thanks for your reports.
63 REPLIES 63
downtheroad
If you are buying a new truck then ANY and ALL of the 3 (Ford, Ram, Chevy/GMC) diesel trucks are outstanding.
Pick your color and get on down the road.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
retispcsi
Well first you need to identify what you mean by larger fiver. To some a 28 Ft unit is large and to others a 40 Ft unit is large. Then there is weight. My point is you need to kind figure out the fiver your interested in. That being said Ram Ford or GM will most likely handle the job.
2015 Mobile Suites 38 RSSA. 2014 Ram CC DRW 4x4 60 gal RDS Aisin 4:10.
DW, Shadow, Remington and Ron. Living the good life till the next one arrives.
valhalla360
Nomad III
Nomad III
x2
Get your favorite brand, check the weight and tow ratings and if they are good, go for it.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
agesilaus
Get a one ton dually of your favorite brand. The differences between them for average drivers is minor IMO. Others may be able to advise you on rear end ratings. I have heard people say that it doesn't matter that much on modern units because or the six speed or more transmissions. I think you mean 3.73 tho not 4.73. This article might help you:
Link
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
