Thermoguy
Nov 22, 2022Explorer II
FireGuard wrote:
A lot of good info by other members so I won’t repeat it.
If you don’t want to remove the lift I would focus on the tires.
If you have a large soft sidewall tire like a C or D rated you can improve your setup.
I would go back to stock size (275 or 285 /70/17) on the factory wheel or equivalent.
You can also get some better tires with a stiff sidewall and way more capacity than many big tires used on lifted trucks.
The right tire will make a HUGE difference in stability.
Good luck.
I was at a tire dealer the other day getting my snow tires put on my daily driver. There was a guy there with a lifted truck getting new tires. The guy brought out a good meaty off road tire for him, load range F.... they were much bigger than the tires on my 2500, LT-E tires... if I recall, 22" but didn't get the rest of the measurements. Just remember the load range F. I don't think those tires would have been the weak spot.
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
