fowlthing
Sep 03, 2022Explorer
Trailer sway milestone 377mb
2020 Model. Pulling with 2021 Ram 2500 Diesel. Have 3000 miles plus with no issues.
Now at speeds as low as 30 mph can hit a bump and side to side rocking translates into trailer sway. Worse going uphill. Had a trip this weekend and put two new tires on the rear axle. My tire shop only had two.
Is this axles out of alignment?? Shocks on the truck? ( 30k miles on truck).
I pulled the tires off and bearings are good. Measured and axles are same distance between tires. Did not measure to the pin.
Tread is still good on front axle. And was good on the two that were replaced. Wear is even. Could not detect that they were out of round when jacked up and spun the wheels.
Any help is welcome. Have years experience of towing trailers. The sway is dangerous. Not a slight annoyance. Thanks.
