CapriRacer
Mar 19, 2022Explorer II
Cummins12V98 wrote:CapriRacer wrote:Cummins12V98 wrote:
..... I would like someone to explain whey they have weight inflation chart for the ENDURANCE if it's not ok to run tires pressures based on actual load. ......
Those are MINIMUMS, not recommendations.
Sure but that is what the tire is designed to support at those pressures right? .....
Yes, but just barely. Not a good practice.
Cummins12V98 wrote:
.....Maybe you can elaborate. Do you disagree with GY tech support or agree that a person up sizing in load range can use the chart for the best ride, tire wear and stopping by adding 5psi to the chart. .....
I am merely saying that the tables are a minimum, not a recommendation and it looks like the GY tech support agrees with me.
Cummins12V98 wrote:
...... Let's forget Jerry's rim pressure rating. If you went to the GY "E" 15" would you run the tires at 80psi or use the chart plus 5psi as GY Tech recommends? .....
I would need some additional information. Like year, make, and model of trailer. What does the vehicle manufacturer specify? Are actual weights available?
In other words, the sort of thing a vehicle manufacturer would go through when they make their specification.
Yes, we know that some trailer manufacturers didn't do a good job of specifying tires and pressures. Is Jerry's vehicle one of them? Do we have reason to disagree with their specification?
These are all questions that I would need to make a recommendation.
Cummins12V98 wrote:
..... Answer this. I am around 4,500# load on each tire and the GY "H" tires were not holding up running them at 125psi with a rating of 4,805#. Now I went with the Continental's with 6,005# rating at 125psi. Would you run 125 psi or lower pressure like 100 that gives 5,200# capacity?
Why so argumentative?
But to answer your question, see the above for how I would do it. Your question doesn't contain the information I would seek before giving an answer.
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 16, 2025
