Traveling from Ramona CA to Needles CA - advice please
Jwrv1978
As the titles says Iโ€™ll be traveling from Ramona CA to Needles CA and Iโ€™m trying to determine the best route. It looks like 78 is off limits to over 40ft, I have a 42ft, part of the way if I take 78 to 86.
Looks like I can go 78 to 79 at Saint Ysabel safely, but I donโ€™t know how good or bad 79 is. Any advice on route to take would be appreciated.
7 REPLIES 7
laknox
There ya go! ๐Ÿ™‚
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
Jwrv1978
Thanks! I looked at my route again. Just gonna stop over in Quartzsite which will split my trip almost in half perfectly between 2 days.
laknox
Why go through Needles? Why not I-8 to I-10 to I-17? Yeah, it's about 30 miles longer, but it's faster. Travel after dark to avoid the worst of the heat. Stop in Yuma for the night, though it'd only be about a 10 hour drive, max.
Lyle
Jwrv1978
One day stop on the way to flagstaff. Not ideal but it works.
TravelinDog
Mmmm...Needles CA in July
Results for Needles, CA
ยท Choose area
Mostly sunny
114ยฐFยฐC
Precipitation: 0%
Humidity: 14%
Wind: 12 mph
Weather
Monday
Mostly sunny
Just say no to the payload police :C
opnspaces
Navigator
Navigator
78 to 79 at Santa Ysabel is the route that everybody going to the desert takes, I've been driving it for 30 + years. It will easily take your 42 footer. In fact in the winter you will regularly see 40 foot motorhomes pulling 25 foot trailers. Once you're on the 79 you could go all the way to 15 north then 215 to the 40.
But for a much easier route with a whole lot less turns just take 67 south to Scripps Poway Parkway. Then straight through Scripps to 15 north and then as above to 215 then the 40. It's a whole lot easier for about 20 - 30 extra miles.
CA_Traveler
I avoid the CA Prohibited roads for several reasons. Someone may chime in with 79 info. North mid day to 40 may not be any more time.
Try the roads and routes thread.
2014 Grand Cherokee Overland
Bob
