Using a Cpap in my AF 27-5
timn
Ok we bought a 2018 AF 27-5 and are leaving in August and I can't figure out how i am going to run my resmed Cpap while boondocking any ideas. I have several USB ports near the head board are there a adapter I can buy? Would appreciate any ideas thanks.
31 REPLIES 31
Trackrig
Your Cpap normally runs off of 110VAC. You should have 110VAC outlets in the bedroom. I'm assuming your 5th has batteries and a converter to supply 110VAC?
You can buy adapters to run them off ov 12VDC from Amazon, but there's no reason for you to do that.
And no, the USB outlets do not have enough power. Your power supply for the Cpap should use 95 to 100 watts.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
CA_Traveler
USB ports have limited power at 5V. Assuming the CPAP uses 12V power then just wire up a matching plug/fuse to the battery.
What are your CPAP power requirements?
2014 Grand Cherokee Overland
Bob
