Apr-21-2016 08:42 PM
Apr-24-2016 04:57 PM
Apr-24-2016 09:51 AM
Apr-23-2016 09:02 PM
Apr-23-2016 07:22 PM
dave17352 wrote:mtofell1 wrote:
Thanks everyone - OP here. I'm too tired to go back read everything I wrote but never meant to imply I don't use chemicals. After a trip I typically dump and then fill with a few gallons of water and a bag of blue powder. This has worked for the last 10 years. After dumping I don't put any waste in the tank until the next trip out.
As for the big problem at hand it seems to be taken care of for now. Before leaving today I filled the black tank with fresh water to wash around while driving then dumped upon arrival, filled with a few gallons of water and a bag of blue powder. The smell is gone. I don't know what caused it but am suspicious of one of my kids dropping something before we got home 6 weeks ago or while the RV was parked. I've never smelled anything like this...... it wasn't a poop smell at all. It was more a sharp gassy smell. Maybe I need to get my kids to the doctor 🙂
It brings up an interesting question though - how do you leave the black tank when stored? I've just always thrown a few gallons of water in it with a bag of chemicals. I never knew they lost potency. Even if they do, with no waste what's the harm?
I always do as you do and have no problems. Before I winterize I do completely drain and flush the tanks and leave them dry because of freezing. If I didn't have to worry about freezing there would always be water in my holding tanks.
Apr-23-2016 03:40 PM
Old-Biscuit wrote:leeper wrote:
I have always wondered how people know that Calgon Water softener coates the inside of a black tank and making it slick. Did they cut one open to see? Look in through the toilet and saw it? How do they know it does this? How much Calgon is put in the tank?
Put your hand in the flow as you drain waste tank and see how slick it is from the Calgon.
Simple......
Apr-23-2016 09:44 AM
Apr-23-2016 07:07 AM
Apr-23-2016 02:54 AM
Apr-23-2016 12:20 AM
Apr-23-2016 12:07 AM
Apr-22-2016 10:27 PM
Apr-22-2016 08:56 PM
Apr-22-2016 05:52 PM
TucsonJim wrote:lanerd wrote:
I'm also a fan of water only...no rv toilet chemicals. When traveling, the only chemicals I'll use is a cup of Oxy-Clean along with a cap full of Calgon water softener and about five gallons of water. The sloshing of the tank during travel will keep the tank as clean as it's gonna get.
Ron
So what is the formula for Oxy-Clean and Calgon that makes them safer for the environment than RV treatment?? :h
Posted By: leeper on 04/22/16 03:25pm
"using chemicals only masks the odor". Is that right. Gee, I thought that was the idea of using the chemicals. That is not septic tank chemicals you are putting in and the tank is not a septic tank. The Black tank is for short term storage of human waste, a holding tank.
Apr-22-2016 03:37 PM
djousma wrote:leeper wrote:
When I read your post I heard that you went camping, used the toilet with no chemicals in it, then drained the tanks, and then you added chemicals after you where done using it. No wonder it stunk! You first put in the chemicals with water, then use it, then you drain the tank of the chemicals and what ever you put in the toilet! Chemicals first and not last when you are done. When you put the chemicals in with a little water and let it sit for several weeks the chemical lost its potency and things got stinky. Chemicals need to be renewed in order to keep working.
I guess the way I read the OP is that he does what I do. After draining the tank, he "recharges" it with chemicals, and water so that it is ready to go for the next time. I don't think they said they used the tank without chems. I guess we wont know until he/she comes back for sure.
If this is new trailer, then I'm going to go with the roof vent might be partially/fully plugged.
