SMarquez's avatar
SMarquez
Water Heater Problems
I have an Atwood water heater that has been acting up for a while now and I hope you can help. It is a pilotless unit if that makes a difference. When I first turn the WH on it takes a couple attempts to light and everything is fine. After 6-7 hours it shuts off and I get the red light at the switch and it won't relight. Once in a while it will try but it seems to struggle and will back fire with a nice POOF that is a little alarming bit doesn't ignite. If I shut it down for a couple hours it will light up like normal. I have taken to just shutting it off when we're not using it but I hate when my stuff doesn't work as designed. I took an air hose to it and got some dust and fine dirt out of it but I lit it up left it on evernite and it shut itself off again. I'm thinking it may be the igniter, maybe it is intermittent or are they a good or bad function only?
Thanks.
