Bowhunter61
Dec 30, 2015Explorer
Craig A wrote:
Could be from the marker light too. My last trailer (2006 Mountaineer) had a bad seal under the spotlight on the roadside, when the light filled up to the level of the bulb, the water went down the wire, behind the refrigerator, across the bar and got the floor on the curbside wet. It took an experience RV shop 9 months to figure this out. After spending $3200 to fix and recarpet, the roof leaked a year later. I just traded the sucker.
So that is interesting, I have another post here where I said I found the rear spotlight lens on that side of the back loose, ends up the screw holes had fatigued and cracked. Hmmmm.....could it be that was leaking and like you said running down the wire? I'll have to check that out. I just assumed if that light was leaking it would run the way the camper was tilted, opposite the corner that is getting wet.
Thanks!!
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 13, 2025
