โApr-01-2016 01:21 AM
โApr-01-2016 02:54 PM
SanMarMor wrote:
People keep saying it's fine to go over the trucks weight sticker ratings. Sure, it will pull, it may even stop, sort of. But if you ever get in an accident, the first thing the insurance company will do, is check to see if you were over ratings. When they find you were, your insurance is no good, and lawyers from the other vehicle in the accident, will come after you with a vengeance. After all, you negligently disregarded the trucks specifications. You are at fault. You can imagine where that will go.
Mark
โApr-01-2016 02:36 PM
Mark
โApr-01-2016 02:12 PM
Mark
I've always been curious if anyone stating the above actually has FIRST PERSON experience with that or is it another internet myth? Sad that you americans live life in fear of the all mighty lawyer. Another reason to move to Canada next year, maybe ๐
Not condoning the overloading or not overloaded conversation, just curious if ANYONE can step up and say that the above law suite actually happened to them.?
โApr-01-2016 01:59 PM
โApr-01-2016 01:41 PM
Mark
โApr-01-2016 01:39 PM
Mark
โApr-01-2016 01:32 PM
โApr-01-2016 01:24 PM
Old-Biscuit wrote:
OVER is over.....
One stays within ratings or justifies not doing so
OP...you will be OVER with that 5vr
โApr-01-2016 12:49 PM
โApr-01-2016 12:43 PM
Cummins12V98 wrote:rhagfo wrote:Cummins12V98 wrote:
Why not buy the RV that your truck can tow within it's ratings????????
States the person that is 2,000# over on the 5er GVWR, and slightly over on the TV vehicle GVWR. Yes with in Axle on the TV.
I know I am over GVWR, so my statement it is their choice, but don't exceed wheel and tire ratings EVER!!!!
Yea but I am special ๐
โApr-01-2016 11:01 AM
โApr-01-2016 10:59 AM
lee worsdell wrote:
Life would be boring if we all did that. Then there would be no one to complain about how much you can pull
โApr-01-2016 09:06 AM
โApr-01-2016 09:02 AM
Me Again wrote:IdaD wrote:Tgator1 wrote:
Truck: '13 Chevy 2500HD, cc, sb, 4X4, SRW, Dmax, Allison. Stock suspension, but will upgrade to Timbrens, and may look into air bags.
Looking at KZ Durango Gold G359RET: UVW 10640, dry hitch 2190, dry axle 8450, NCC 2960, GVWR 13600.
Hitch is a Reese 20k slider.
I think you'll be just fine with that setup. Probably over GVWR, but within your axle weight ratings. I'm not an expert on GM trucks, but I would bet your truck is identical to a SRW 3500 aside from a softer rear spring pack, which Timbrens or airbags would address (if necessary). I don't think the payload sticker means much on 3/4 ton diesels because the GVWR is restricted by class, but tire and axle ratings are important.
I was at 6750 on my rear axle of my 3500 RAM SRW with a trailer the grosses 1200 less on our way to Arizona. These new trucks are heavy!
Chris
โApr-01-2016 08:55 AM
