What do you think?
suz1500
Hi, need opinions on this toy hauler pairing...2011 Ram 1500 4.7L 4x4 Quad Cab against a 2016 Grey Wolf 26RR Toy hauler.
Toy hauler dry weight 5110 lbs.
hitch weight 715 lbs.
GVWR 7715 lbs.
Truck is GVWR 6700 lbs.
Base Wt. 5178lbs
GCWR 12,500 lbs.
Max. trailer 7150 lbs.
15 REPLIES 15
Dirtclods
You can tow anything with anything https://www.youtube.com/watch?v=AyXgMal3C1U
AAA Motorcycle RV Plus
misterpowertool
I'm towing fine with my combo which is with a
7000 lb loaded TH when we bring the golf cart. We camp mostly in the Sierra National Forest. I'll slow down to 45 mph on long grades 6% or better. Payload on my truck is 1850 lbs AS EQUIPPED. As it usually is on "1/2 ton" trucks, towing a TT or TH, you will reach payload capacity before max tow capacity. Find your payload cap and do the math for that first. Also, my In-Laws Tundra 5.7L Crewmax Platinum 4x4 did a fine job towing our TH, but felt a bit soft in the tail. During our last trip with it, I looked at the payload sticker... 1295lbs AS EQUIPPED. With the inlaws onboard, we were over by about their weight!
2012 Nissan Titan KC Pro4X
2015 Genesis Supreme 19SS
2010 Honda EU3000is Gen
1968 Beautiful Wife
2006 Baby girl
suz1500
Yes, I have many years towing with small 4x V8's, the 4.7 rates out at 310hp@340lbs. torque...I'll never be close to the rated max tow weight, even this being a tow hauler and with us "loading" accordingly. Test hauled the unit on the weekend, with truck in the Tow/Haul mode, hauled trailer through a variety of terrain for over two hours, it pulled trailer quite well, sure speed was down on steep hills, but who's trailer doesn't, trans temp and shifting and rpm's were ok never over 1700-2000 rpm.
JIMNLIN
The trucks chassis won't have any problems carrying that trailers hitch weight but IMO your not going to like towing performance with a 7k trailer with a very small 4.7 gas engine.
Post around on other RV websites and see what other 1/2 ton truck owner have to say....... who have actual experience with a 4.x small gas engine towing a 7k trailer.
suz1500
Thanks for the link, I don't get it...is it not saying max. trailer weight is 7150lbs?
Dirtclods
Another towing guide:https://www.ramtrucks.com/shared/pdf/2011_RAM_Full_Line_Tow_Chart.pdf
Dirtclods
GVWR 7715 lbs.
Base Wt. 5178lbs
GCWR 12,500 lbs.
Towing guide http://www.ramtrucks.com/en/towing_guide/
suz1500
Thanks for all the replies.
FireGuard
Seems a little light for a 26' TH.
My 21' Ragen with 1/4 tank of water has a tongue weight of 1100 lbs and is around 7k lbs with no toys and basic camping suppies. THs also pull like a brick.
A friend towed my TH with his Tundra which is close to the power of the HEMI. It did OK, but he definatley knew it was there.
With airbags and good tires it sat level but was over his GVW.
My 15 Ram 3500 Cummins handles it well.
Bigger truck or smaller (16-18') TH is my recommendation.
Good luck
13Jeep Wrangler
07 Ragen 21FB
12 Yamaha Super Tenere
14 Suzuki DR 650
dehaile
I agree. Your truck will be screaming (high rpm) just to maintain speed on level ground. Even a Hemi will have a hard time.
shum02
That 4.7L small V8 will be on it's knees even with the dry weight. Been there and let me tell you you will not be looking forward to even approaching a small hill, even here in pretty flat Southern Ontario, Northern Ontario - forget it. Loaded up she'll be in second gear screaming just to stay with traffic, if loaded on a hill you'll never even approach the speed limit more than likely.
Dude, should have got the Hemi.
2006 F350 Lariat FX4 CC 4x4 PSD
2007 KZ2505QSS-F Outdoorsman
handye9
suz1500 wrote:
Calculations I've done show max. trailer weight 7150#
max. tongue weight 1072#
???seem correct ????
That's not enough capacity to support that trailer.
That 7150 max tow number, does'nt include any weight capacity for aftermarket accessories, passengers, pets, or cargo in or on the truck. It was calculated with a driver only. Any of these things added to the truck, reduce that max tow number and available payload capacity, pound for pound. A weight distributing hitch,will eat up to 100 lbs, by itself. If you add 650 lbs of people, accessories, and cargo, the true max tow number is 6500 lbs. That trailer will easily exceed 6500 lbs.
Besides the truck numbers you have posted, you also need to look at it's payload, GVWR, and axle weight ratings.
18 Nissan Titan XD
12 Flagstaff 831FKBSS
Wife and I
Retired Navy Master Chief (retired since 1995)
NC_Hauler
Forget dry weights...no one tows rv dry. Use GVW of unit and be more realistic about the weights. Do the math and some common sense to figure if your truck is up to task toing the TH you want to purchase. You would possibly go over your trucks GCWR...
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
suz1500
