- transamz9Explorer
rvshrinker wrote:
mrkoje wrote:
rvshrinker wrote:
I am getting a full ton RAM but only want the SRW. It will have the diesel and the AISIN transmission, it is a short bed Mega Cab.
I just don't want a dually. I would rather have a smaller trailer or even a travel trailer than a dually.
I wouldn't spend the extra money for the Aisin unless you're getting a dually. There are a lot of reasons but mostly It's 3k that you're not going to get much extra use out of especially if you're a recreational rv'er. The 68RFE is solid tranny that is more than capable for the weights a SRW will be pulling.
I've got a 35ft toy hauler that I pull with a mega cab. I used to have a long box crew can but I switched to the mega because of the extra space in the cab. It's really nice to be able to recline those rear seats! I did buy a B&W slider hitch but I have yet to use the slider once. The way the front if the toyhauler is designed I can still make some sharp turns without hitting the cab!
I know I won't need the AISIN but I just love the way it sounds and drives. It is worth the $3000 to me and amortizes to only 5 cents per mile over 60,000 miles so I can justify it easily as a 'luxury purchase.'
I'm feeling really confident now about what I can pull with the SRW and glad to be going that direction.
I really like your truck by the way!
I tow a 72' long trailer that weighs 20,000+- with my SRW Mega Cab so I think you'll do just fine. - rvshrinkerExplorer III
I really like your truck by the way! - It depends so much on the 5th wheel design. I'm currently pulling a 38 footer with a 2500. Empty weight of the trailer is 10,600. I have never had any bad feelings while towing with my combination. Weight and axle location on the trailer matter much more than length.
- mrkojeExplorer
I've got a 35ft toy hauler that I pull with a mega cab. I used to have a long box crew can but I switched to the mega because of the extra space in the cab. It's really nice to be able to recline those rear seats! I did buy a B&W slider hitch but I have yet to use the slider once. The way the front if the toyhauler is designed I can still make some sharp turns without hitting the cab! - rvshrinkerExplorer IIImegacab only comes in short bed.
Definitely not looking at anything over 15k GVWR! How about length - from a stabiity standpoint, it sounds lilke there is uniform agreement that a 25-30' length would be comfortably handled by this vehicle? - tinner12002Explorer
rvshrinker wrote:
payload is around 4300 so think I'm good there. I read that longer and heavier fivers deserve a dually for stability; up to what length and/or weight would you consider a SRW ok?
Nothing over 16K GVWR. - leggyExplorerPersonal experience, 40 ft 5er 16000 gvw with f450 DRW, traded it for f350 short bed SRW and truly felt no difference in towing. Now we have a 37 ft grand design reflection 15000 gvw and have not had a single issue. No slider hitch either, but I am definitely cautious when turning tight.
- rhagfoExplorer IIIYou might check, but I think you gain about 600# to 800# payload with a long bed.
- Old-BiscuitExplorer III
TxGearhead wrote:
If you got that 4300# of the Ram website, it will likely change when you get the truck. Leather trim, bed spray, etc. will drop it. I'm at 4018#. Our 5th is 12,500 GVW, any heavier and I would go dually.
And I tow a 14K (13,873# scaled) 5th wheel with an old 2007 3500 SRW and don't need a dually
2016 Megacab.....good for 15K easily and not be unstable, over loaded, white knuckling OMG tow - TxGearheadExplorer II
About Fifth Wheel Group
19,013 PostsLatest Activity: May 19, 2025
