- RV_wandererExplorer
rexlion wrote:
Lube? How about the thick brown stuff and the thin yellow stuff? :D lol
That would probably work if your diet included a lot of grease and oils! :B - rexlionExplorerLube? How about the thick brown stuff and the thin yellow stuff? :D lol
- bob213ExplorerStay away from petroleum based products like Vaseline on all new gaskets and o rings. They are not made of the same materials of old and will get brittle. We have an old undersink water filter that says to put Vaseline on the o ring. The new water filter for the trailer specifically states not to use Vaseline. Toilet seals get hard with Vaseline also. Plumbers grease or silicone paste are the preferred products by the mfgs.
- Dave_H_MExplorer II
greende wrote:
Home Depot has Plumber's Grease. Silicone Paste. Works Great on my toilet seals.
That is what I am gonna use if I have to ever face that issue again. - greendeExplorer IIHome Depot has Plumber's Grease. Silicone Paste. Works Great on my toilet seals.
- TrackrigExplorer IIDon't forget to lube the slide rods occasionally with silicone also.
Bill - downtheroadExplorerWell, if you want a true O-ring and valve lubricant then spring for this. We used this in the scuba industry for the O-ring seals on very expensive underwater camera housings.
Click Here. - old_guyExplorernothing wrong with Vaseline or silicone
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 13, 2025
