Aug-10-2016 07:00 PM
Aug-16-2016 05:28 AM
Aug-15-2016 12:50 PM
Vanished wrote:
http://academic.brooklyn.cuny.edu/physics/sobel/Phys1/eqm.html
As D2 changes (say moving from pin to jacks) the sum of the moments still needs to be 0... F1 (weight on tires) does not change, only the F2 increases assuming the CG is in front of back wheels..
Aug-14-2016 12:02 PM
Aug-12-2016 11:38 AM
Aug-12-2016 06:49 AM
Aug-11-2016 02:19 PM
Aug-11-2016 02:05 PM
Aug-11-2016 01:04 PM
Aug-11-2016 12:58 PM
rhagfo wrote:Vanished wrote:bpounds wrote:SoCalDesertRider wrote:
Now, on the pin weight versus jack weight issue, if you were weighing just the jacks by themselves, no trailer axles on the scale, that would not be the same as the pin, because there is about an 8 foot length difference between the pin to axle measurement, versus the jack to axle measurement. The jack weight will be significantly higher than the pin weight.
Interesting thing about this statement (which is true), is that it means the weight on your tires is less when your trailer is sitting at camp, than when you are hitched up. The weight forward of the landing gear is lifting weight off of the tires.
Just thought I would add that in to further confuse some.
I'll bite - again (and hopefully I read it correct this time..)
The trailer has a center of gravity.. the distance to the rear wheels from the center of gravity hasn't changed any - I don't think the weight on the rear wheels changes any if it's supported by a tripod or the jacks..
Has nothing to do with the center of gravity. It has to do with the two points of support, the closer they get to each other the more weight will move from one to the other. That said that has nothing to do with getting the total weight by having the LG and axles on the same scale. Once you have the total weight then support the pin on the hitch, raise the LG, current weight now on the axles from total weight equals pin weight! Plain and simple.
Aug-11-2016 12:51 PM
Aug-11-2016 12:30 PM
The trailer has a total weight.. In the OP's post example of 14,500..
He has two weights of 2900 (landing gear) and 11,600 (axles) as examples..
The question we don't know is where is the center of mass of the trailer.. The total weight of the trailer is the distance * force of the axles (11,600) plus the distance times force of the landing gear (2900).. the question we are trying to answer is what would the pin weight be? the answer is it also has to be 2900 lbs total - but it's further from the center of gravity - so if it's 16' from the center of mass compared to 12' for the jacks (both random examples) in theory it should be 2175 lbs if the examples above are used..
The OP's method can correctly calculate total shipping weight and axle weight but does indeed give an incorrect pin weight..
:S
You just don't get it do you?
Total trailer weight and on same scale pad gives total trailer weight. Lift landing gear and none of the TV is sitting on scale plate, now you get trailer axle weight, subtract that from total weigh is the True pin weight, plain and simple!
Aug-11-2016 12:27 PM
Aug-11-2016 10:53 AM
Aug-11-2016 10:51 AM
