Sep-12-2007 09:05 PM
Feb-09-2009 04:59 PM
Feb-09-2009 04:42 PM
Feb-09-2009 04:22 PM
Lakemann wrote:
O.k. heres the deal, weighed my truck today. Its a 2008 Dodge 2500 Cummins 6.7 with an auto trans and an 8' bed. She came in right at 7620# with just me and a full tank of fuel. After reading ramcneal's post above me, its hard to imagine that an extra 2 feet of driveshaft,frame and sheet metal would end up being 580# more. Should I have gotten a shortbed and used that extra 580 elsewhere?
Feb-09-2009 01:28 PM
Feb-09-2009 12:27 PM
Jan-31-2009 02:43 PM
Jan-25-2009 06:40 PM
Jan-25-2009 08:44 AM
Jan-25-2009 06:22 AM
Jan-22-2009 12:05 PM
Jan-22-2009 08:05 AM
Jan-22-2009 06:24 AM
DW-gray wrote:
Today I weighed the TV and RV. The RV's fresh water, gray water and black water tanks were filled with water to maximum. I also filled the RV gas tank. By my calculations the fluid weight should be about 2,412 lbs. I doubt I'll ever come close to that weight while traveling but was enough to give me a guideline. Here are the measured weights.
TV + RV
TV Front: 4,580 lbs. (620 lbs. under GAWR)
TV Rear: 7,560 lbs. (1,790 lbs. under GAWR)
TV Total 12,140 lbs (60 lbs. under GVWR)
RV 12,460 lbs.
GCW 24,600 lbs.
Pin Weight: 4,100 lbs.
I also conducted a braking test per the California DMV code. In a nut shell, the code states that my type of vehicle combination should stop within 40 feet from the speed of 20 MPH. Although this was unscientific, I was sure I stopped less than 20 feet.
Jan-21-2009 06:43 PM
Dec-30-2008 05:33 AM
Dec-27-2008 06:18 PM
