When camped at camp grounds do you
blue_trawler
Leave your gray or black water valve open? I always leave black tank closed and grey water open until we are going to leave. Meaning a day or two in the grey water tank to flush out after draining black water tank.
Thanks
Bruce
38 REPLIES 38
rhagfo
Well I have three, Black, Galley, and Grey. All stay closed until I need to drain, that way I have plenty of clean water to rinse the black water leavings.
Sandia_Man
Standard operating procedure when camping with sewer hook-up, if we're there for only a couple of days both stay closed, we will connect stinky slinky just prior to dumping in that scenario.
Lantley
Both closed until they are full enough to dump. Leaving valves open exposes tanks to fumes critters, and insects which may live in sewer lines.
19'Duramax w/hips, 2022 Alliance Paradigm 390MP >BD3,r,22" Blackstone
r,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
BakFlip,RVLock,Prog.50A surge ,Hughes autoformer
Porta Bote 8.0 Nissan, Sailun S637
path1
(Obviously your talking dumping with hook ups. Just wanted to add that in case thread turns into a dumping post with some peoples fascination with poop)
I leave both of them closed until I dump. When we used to leave gray valve open but every so often depending on the site we would get a few odors up thru shower drain. To avoid that I keep both valves closed and give the gray tank handle a pull every morning. The black tank valve we always keep closed until we dump.
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
mr__ed
Same as you. A few days before I empty the black tank I close the valves in the two grey tanks and use that liquid to flush the hose after draining the black water.
Mr. Ed (fulltiming since 1987)
Life is fragile. Handle with prayer.
2007 Hitchhiker II LS Model 29.5 LKTG (sold)
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition (sold)
sch911
I keep the gray open until just before the black needs to be dumped. Then allow the gray to fill some and use that to wash the hose out after dumping the black. Our black requires dumping about twice a week.
OEM Auto Engineer- Embedded Software Team
hmknightnc
That's pretty much SOP for any of us with experience RVing
rv2go
That's the way I do it also.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
I'm here #4335
Blog
Busdriver
That's the way I do it!
Busdriver
2019 2500 Chevy Duramax , - 2017 Grand Design 303 RLS
