- AZ_T_TExplorer
mileshuff wrote:
At what point do you need airbags? My new 5'er isn't particularly heavy. About 9000 loaded and about 1700 hitch weight + 175 lbs for the hitch itself.
I think it's just a personal preference. I am well under all of my max weights, but I was experiencing porpusing and I also wanted a stiffer rear end while towing. The airbags helped both. - NorskemanExplorerAir bags for me - use them on my last 3 trucks - Air Lift LoadLifter 5000 air bags. Inflate to about 50 lbs loaded and 8 lbs unloaded.
- big_bird_2ExplorerI have Firestone air bags with a compressor and controls on my 2009 F250. I did the install in about 2 hours. It is a 3-4 on the DIY scale. When I need air I push a button. The gauge that comes with the controls tracks the amount of air pressure. When I want to disconnect my FW I push the same button in the down position and air is released. What could be simpler? I do have the compressor installed inside the cab and it is loud.
I understand new 350/3500 trucks ride more like a 250/2500 and have a greater payload. A new truck is about $52,000 MSRP and air bags are about $700. - Splashers3ExplorerI opted for airbags (with the samll compressor that fits nicely under the hood)....its not that hard for me to flip a switch on my dash to adjust them on the fly....
Have had for over 4 years - no issues. - mileshuffExplorerAt what point do you need airbags? My new 5'er isn't particularly heavy. About 9000 loaded and about 1700 hitch weight + 175 lbs for the hitch itself.
- goducks10ExplorerAfter owning both airbags air more versatile. Only issue is when pumped up the rear will rise, then when unhitched the rear is still jacked up and the ride will be stiff. If you're out camping and want to run around then you have that to deal with. If you get the compressor then it's a non issue.
Helper springs are a easier to install, although the bags aren't that hard. The springs will only give you a certain amount of support unlike the bags which are adjustable.
Another alternative is Timbrens. Real easy to install and no air to deal with. The truck rides exactly the same with them as they sit 1" above the axle. - LVTOCMPExplorerI chose the "Super Spring" for my truck. Very easy to install,rides very nice loaded and unloaded, don't need to ck air pressure, don"t need to carry air compressor, don't need to worry about replacing rubber air boot. All I need to do is hook up and drive. My 2 cents.
- Paul_ClancyExplorer IIAs said one is adjustable (even from cab in motion) one is not. Pick your best.
- mark5wExplorerHave had both. With new 13 ecoboost I installed Roadmaster Active Suspension. Activates when needed great ride when not. Much better than having to fill bags and then empty after trip. Plus helps if there is any side to side motion and helps with the axle wrap when taking off from a standstill. A lot easier to install than airbags and no airlines to fish thru. Plus it will never get a leak.
- Airbags ride better... If you do not need the help all the time , think about Torklift ,, they makes a part that is bolt on And it is called StableLoad...When not used you swing it out with a socket.. Not sure how it works but after looking online , it looks really good....Joe
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
