I don't have on but have loaded a couple of rangers in other TH's. You have 16' of length so the only problem would be height. If you have a roll cage that will be the limiting factor getting into the trailer as the inside ceiling is usually higher than the top of the door frame.
USN EN2
2012 Ford F250 SC, 6.7L TD
2015 Voltage 3200
2004 Honda GL1800 Reverse Trike
