Oct-05-2016 10:35 AM
Oct-07-2016 12:35 PM
2oldman wrote:I agree - and since there have been 6 pages of suggestions, and many off topic posts with quite a bit of moderation needed, I think it is time to close this thread and move on to something else.JIMNLIN wrote:That would be a she, and she appears to have lost interest.
. At this point it would help if he would come back and pass along his thoughts or help with other options.
Oct-07-2016 12:12 PM
Oct-07-2016 12:06 PM
Oct-07-2016 11:12 AM
Greene728 wrote:
Wow. Can you say "derailed"?
Some folks minds aren't going to change, and some folks know it but refuse to accept it.
Carry on!
Oct-07-2016 10:41 AM
Oct-07-2016 09:00 AM
Oct-07-2016 06:50 AM
FishOnOne wrote:
One topic no one is discussing is stability. Compare the two in how the springs are located. The coil spring setup has the springs mounted away from the wheels and the leaf springs are mounted closer to the wheels which will always produce better stability. Also leaf springs I believe are more stable compared to coils. Having said that all Rams with coils have a stabilizer bar to supplement the stability that the coil setup can't alone provide.
Oct-07-2016 06:40 AM
Cummins12V98 wrote:
^^^^^He knows RAM's
Oct-07-2016 06:05 AM
Coach-man wrote:
2500 & 3500 the same, but 3/4 and 1 ton are not???
Oct-07-2016 05:56 AM
Oct-07-2016 05:19 AM
Oct-07-2016 05:03 AM
RustyJC wrote:Coach-man wrote:donn0128 wrote:
3500, you will never regret havine enough capacity.
Yes, until you pull into a parking garage, while your out exploring on your travels!
2500 and 3500 SRW are the same size.Coach-man wrote:
Also, keep in mind many 3/4 ton vehicles are the exact same vehicle as their 1 ton SRW counterparts! Difference, in some states the 1 ton gets extra taxes and/or license requirements! Do the research, check your anticipated pin weights, check the ratings of the tires, and wheels. If RAM, is a "Heavy Duty" with the same engine, transmission and rear end as the 2500? Make an intelligent informed decision!
The 3/4 and 1 ton Rams are NOT the "exact same vehicle" as I've detailed in this thread (to the chagrin of some).
Rusty
Oct-06-2016 08:20 PM
Cummins12V98 wrote:rhagfo wrote:
Get the 3500 SRW with air ride.
Agree but also add the Aisin trans.
Oct-06-2016 06:17 PM
Me Again wrote:wilber1 wrote:
I'm still waiting for an answer to my question. If the real capacities of the trucks are within 150 lbs of each other, why don't SRW 3500's also have a coil rear suspension?
Call RAM and get it from the horse mouth! They are the ones that decided the 2500 and 3500 were no longer going to be different only by the rear leaf springs.
