These TP threads always cracks me up.......
No one gives a second thought to pooping and using TP in their homes but when it comes to an RV all kinds of 'ideas/methods' pop up.
When you flush a toilet at home the stuff goes down into drain line with 1 1/2-2 gallons of water which does not push all that stuff from one end of house down and out drain line to the sewer line or septic tank. The stuff sits there and waits for the next flow of water to help move it along and then waits again...
Rv toilet dumps directly into a holding tank thru a 3" line then floats around in liquid until dump time and then gets carried out in a big gush of liquid flow for a short distance down & out a 3" line......done.
Sheesh......it ain't rocket science nor does it have to be 'special'
Go to the bathroom, flush the toilet, dump when tank is almost full, rinse, add a couple gallons.
As for TP....I use 2 ply soft fluffy WAD and it gets flushed.
