Warany Impact - Full Timing
Jgeorger1
We are snowbirding in a Montana High country, and considering going full time. Since the Keystone warranty excludes "residential" use, I am assuming I will void any warrnaty coverage by full timimg...Correct?
If so, are there protection plans that can be purchased to cover such things as water heaters, power stabilizers, furnace etc?
No complaints with the rig so far, but concerned it is not built to the task.
Thanks for any advice.
14 REPLIES 14
Moderator
Moderator
Moderator
Moved from 'General'
PawPaw_n_Gram
As a full-timer - we find that warranties are seldom worth the paper they are written upon.
Because the manufacturer wants the rig dropped off at a dealer for any issue. They will not pay for a mobile technician.
One example - water pump acting flaky. Works some times does not other times. Was near Fort Lauderdale, FL. Mfr of the pump wanted the rig taken to a local dealer. They would NOT pay for a mobile tech, and would not consider his opinion as to what was wrong. Only one dealer was available south of Orlando - and I would have to reserve a 'work spot' a month before I bring in the rig. And it was taking them approx six weeks from when the rig was dropped in their lot until their techs could get to working on the possible warranty issue. No - we could not stay in the rig on their lot.
Second example - Suburban Water Heater developed a pinhole leak in the top of the tank - would only leak when heating water. Suburban did drop ship a warranty replacement water heater to a service location/ dealer in Hartford, CT. The best they could give us was to bring the rig 85 miles - drop it off on a Saturday afternoon, and they might could get it fixed on Monday. Or pay $120 for a tech to drive out to our location and install the new WH. (Approx 24 gallons of fuel to tow the rig at $2.70 per gal local price - so only really cost me about $55)
Third example - electrical converter stopped charging battery/ supplying 12 volt at Zion NP. Mfr wanted me to take the rig to Salt Lake City to a dealer who might be able to get to it in a couple days. Instead we went on with our plans to Las Vegas and paid for a new converter (better model) and labor charge to have it installed by a mobile tech in less than three hours.
Fourth example - had a hub failure. Happened 5 miles from where we bought the rig. Got it to them, they had a tech look at it first thing the next morning. Discovered broken welds where Dexter Axle was welded to Forest River bracket (Dexter process) was allowing that side of the axle to move forward and backward while under tow. Documented the info - and Extra-Ride extended warranty authorized replacement of both axles. Took 31 days to get fixed when we had to live at my daughter's house. Long delay was because Dexter only builds Forest River axles one week a month and we were at the wrong end of the cycle.
I've seen many posts over the years where folks make the trip to the manufacturer plant rather and put up with the rig being in a shop for four - six - eight weeks or more and having to live in a motel.
If you need the rig for your full-time home - you just have to pray that nothing serious happens and be prepared to pay for a repair from a mobile tech rather than fight with/ wait for approval for a warranty repair.
Had we had to pay for the cost of housing for a month after the axle replacement - it could easily have been more than the total cost of the repair without any warranty.
Full-Time 2014 - ????
“Not all who wander are lost.”
"You were supposed to turn back at the last street."
2012 Ram 2500 Mega Cab
2014 Flagstaff 832IKBS TT
Old-Biscuit
When they (RV MFG) see your 'domicile' address they will know you are FT.
It is NOT a secret. Very little is anymore
CT_WANDERER
You are not FT, you are on an extended vacation.
Jgeorger1
Helpful advice .Thank you all
tatest
I consider warranties on RVs to be a non-issue over the long term. 1-2 years, generally covering only "defects in materials and workmanship" a warranty is not going to cover whether the thing was designed to last a long time using it the way you want to use it.
If considering long term service plans, often billed as "extended warranties" pay careful attention to the details, what is included, what is excluded, a procedures necessary to getting something paid.
Tom Test
Itasca Spirit 29B
doxiemom11
I don't think warranties last long enough to worry about it anyway. 90 days, 1 year, 2 years if you are lucky. I guess they would only know you are full-time and you can't leave the rv with them for months for minor repairs, or ask to stay in the rv while repairs are made.
Old-Biscuit
Folks FULL TIME in just about every conceivable type of RV from motorcycle pull-alongs to Class As with 3 A/C Units
Warranty is rarely a deciding factor ---most are only for 1 to 2 yrs
If you go full time then get FULL TIMERS Insurance....same or upgraded policy like you have on the S&B.
That insurance coverage is more important then any rv mfg. limited warranty.
And learn to be self sufficient and do your own repairs. When you need help....call a mobile RV repair.
jplante4
This was discussed ad nauseum last year. The consensus of those threads was that this statement is a lawyer-generated CYA statement and has absolutely nothing to do with the ability or legality of using the rig for full-timing.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
K_Charles
Even the OP said he was"concerned it is not built to the task". So both the manufacturer and the OP know it won't last long full timing.
Colo_Native
midnightsadie wrote:
just curious ,how are they going to know your a FT?
X2 what they don't know won't hurt them as they say!
2015 Winnebago Forza 34T
pushed by a 2011 Fusion Hybrid or 2020 Escape Hybrid
Retired DFD
Chris_Bryant
All of the appliances are covered under their own manufacturers warranty, which are only limited by commercial use.
-- Chris Bryant
midnightsadie
goducks10
Montana HC's are built to be a light version 5th wheel. Everything in them is made lighter and therefore won't hold up as well as a designated full time 5er would. JMO but any trailer that uses OSB in it is not considered to be built strong enough for FT'ing. If they're using OSB board then they're purposely cutting back on strength and longevity. Where else are they cutting corners?
How long of a warranty do you have left? And how long do you plan to FT?
There are many after market warranty ins plans you can buy. Make sure you read the fine print 1st.
