Water Heater on or off when Full Timing
CabinetmakerII
My wife and I have been RVing for 30 + years and Full-Timing for 3 years. We have had more than one conversation about leaving the water heater on to ensure we have hot water when we need it, or to turn it off when not in use and risk not having hot water when it comes time to do the dishes or take a shower. Wondering what others do... also, do you run propane or electric?
Cabinetmaker
2021 DRV 39 DBRS3
2017 F-450 4X4, Riece 24K Hitch
2011 F-450 4X4, Companion 18K Hitch, Air Bags (Retired)
2012 Cyclone 3800, 5th Airborne Kingpin (Retired)
2018 Polairs 1000 XP Side by Side
27 REPLIES 27
CabinetmakerII
gbopp wrote:
I don't see this as a full timer question. I think it applies to every RVer.
It doesn't take long to heat the water. I don't think there is any 'risk' of not having hot water when you want to do the dishes or shower. Just plan ahead.
FWIW, I turn mine off when I'm not actually using hot water.
Maybe your water heater isn't working properly if it is taking a long time for the water to get hot?
Water heater is brand new. Just had it replaced because original sprung a leak. One of the reasons for my question...
Cabinetmaker
2021 DRV 39 DBRS3
pianotuna
Nomad III
Nomad III
I am fortunate to have a ten gallon propane/electric water heater.
I find that if I allow it to reach full temperature in the morning--that there is enough warm water to do the supper dishes.
Regards, Don
Old-Biscuit
avan wrote:
...and when parked in a campsite, throw some jacks down and let the air out of the tires...
Guess 'avan' REALLY doesn't like water heaters being ON :H
:B
avan
www.putt10.net
Old-Biscuit
I like to keep things very simple....FT RVng or just out for a camping trip.
After parking and setting up I turn on water heater, furnace or A/C Unit and check that fridge is still on (never gets turned off---always in AUTO)
I like to have HOT water when I WANT hot water...not 15-20 minutes later.
I like HOT water not luke warm water
I like 'Convenience'
SO appliances are ON ready to be used or being used.
Electric when AC Power is available otherwise Propane as it is NOT all that expensive (if it was about 'costs' I would not have an RV).
Bill_Satellite
I would only leave the HW heater on full time if I am connected to electric. If your unit does not have an electric option there is an inexpensive option to add electric heat to the unit.
If I was running propane only I would not leave it on 24/7 but I would turn it on before going to bed and turn it off after the showers are over. You can turn it on before dinner for some additional hot water and that should be about it.
Can't we all just get along?
DutchmenSport
I'm not a full timer, but our camper is parked at home and we sleep in it almost every night, until temps get below 10 degrees. Then, trying to heat is just costly and me move into the house. So, our camper is used "almost" full time. I always said, we bought this house so we had somewhere to full time in the camper!
Anyway.. water heater?
At home and when camping, previous camper ... electric on all the time if there was water in the water heater. The only time the water heater was turned off was when the tank was empty.
Current trailer... I found the electric draw on the current water heater is pretty steep. Considering we do so much in the camper all year round, it's very easy for us to exhaust 30 amps, pretty fast. So, at home, we use propane. I (mostly) leave it on all the time.
Same when camping. With the air conditioner, hair blowers, coffee pots, toasters, it doesn't take much to pop the main breaker in the camper. Turning off the electric from the water heater solves this problem. On our highest electric usage days, with the water heater on gas, we never blow the breakers.
Now ... recently, (at home), we've been showering inside the house a little more. The "need" for hot water in the camper is not so great. And as the temperatures get colder and colder now, the camper will soon be winterized and we'll be using a port-a-potty until it's not feasible to heat the camper any more.
So, recently, I've been shutting the hot water off completely, as we're not actually using "hot" water all that much.
When we decide to use the hot water and it's been turned off, we warm up the water with both gas and electric for a faster recovery. But then, once hot, I'll flip it back to gas.
I have found, the water heater can run almost all summer on gas and still not use up a 30 pound propane tank. It takes so very little. But seems the electric usage popping the breaker with other things running is a real annoyance. So we use gas mostly with the current camper. Off when not actually it, and always on all the time when camping (anywhere else than home).
rhagfo
I leave both on, donโ€™t use that much propane.
gbopp
2oldman
I wish more people would realize how loud one of those gas wh's are at 3am.
downtheroad
What did you do when you didn't live in an RV? Did you turn your water heater on and off as needed?
Leave it on full time. Use electric side.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
Trackrig
Do you turn your hot water heater at home?
If on electricity, leave it on. If on propane, turn it off if you want, the little bit you save isn't worth the bother.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
2oldman
Electric when available, propane intermittent.
