โOct-18-2015 01:55 PM
โOct-18-2015 02:40 PM
โOct-18-2015 02:24 PM
Old-Biscuit wrote:
Just because it is new doesn't mean it was installed correctly.
Sounds like installer didn't use teflon tape where needed, use new washer/gaskets in fittings and/or tighten fittings properly.
I would go back and check each fitting/connection
Cold water inlet nipple, cold water line connection/fitting
Hot water outlet nipple, hot water line connection/fitting
Bypass line connection/fittings
Electric element & gasket
T&P Relief Valve
Drain Plug
โOct-18-2015 02:06 PM
