05 Monaco Cummins 300 running warm to hot
was_butnotnow
At times gets a beeping when the Cummins 300 goes above 200 deg. Starts slow and gets louder at the temp goes up. A/C off and pulling Buick Encore on a dolly.
Had been on dusty road so washed the radiator. Seemed to help but later going in I 15 north in Utah starts running on the top edge of running hot. Doesn't stay hot but goes in and out with the load.
Fluid is 1/2 between the lines.
This is a new to me MH so no history.
Any ideas.
Looking for Cummins diesel service places and found one on our way north at Color Country Diesel in Cedar City UT,
Is there something I should try before I hand it off to a service center.
BTW I get no dash warning lights just the low and louder beeping as the temp goes up. Never gets above 225 deg. BTW daytime temp on the road 100 deg. Did the same things yesterday heading north to Kingman AZ in the heat. It does drop down when not under load.
Heading to Idaho as camp hosts for the summer.
Now in a 05 Monaco Cayman DP 36 PDQ
Traveled many years in NuWa Hitchhiker 5th wheels.
Travel Journals and Adventures of people living this lifestyle
Hitchitch.com
Personal blog with our own travels. www.fulltime.hitchitch.com
18 REPLIES 18
was_butnotnow
I did a Google for a scanguage-D will look into that for sure....
Been pulling a 5er for 12 years a full-timer and now a DP and this is all new again. WOW
Thanks
Hitchitch.com
was_butnotnow
Rear
Hitchitch.com
wolfe10
Rear or side radiator?
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
jplante4
First of all, you need to get the actual coolant temp from the ECM. I can get my dash gauges to change by turning on the lights. A scanguage-D or something will get this data.
May be counter intuitive, but a higher RPM will aid in cooling, so maybe a downshift under load would be called for. Putting the RPM closer to the max power / torque rating will lower the stress on the engine and circulate the coolant faster removing more heat.
Honestly, I'd be happy with 225° on a 100° day.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
