06 Fleetwood Excursion fuse for driver and pass fans?
Offroadr
Looking for the fuse for the fans. I looked at the panels behind the swing out table under dash.
2 REPLIES 2
allbrandauto
my fuse on my 2007 fleetwood bounder was in the bedroom by the circuit breakers for my 110 had separate 12 volt fuse box there
dougrainer
Look at the Circuit fuse board in the outside storage compartment . Doug
2. Fleetwood Battery Control Center
12-volt - This panel is located in the driver's side power cord compartment. This
electrical center contains battery disconnect
systems, entry step, and some other automotive circuitry.
