Our MH had a blowout that tore out wiring. Now our overhead lights on the driver side will not work. Possibly others, the wall light above recliner may not work.
1BryNelson wrote: You need to find the wiring bundle that's near where the tire blew out. A piece of the tire must have hit and damaged you wiring bundle.
Bry Nelson and a yet to be discovered MoHo momma. '99 Pace Arrow Vision 37ft F53 chassis (plugs tightened) Allure flooring, 15k BTU front a/c , 6-6 volt batts with 1120 watts of solar Magnum inverter Remote BMK Trace C40 2005 Ford Ranger "Toad on a pad".
