13500 btu versus 15000 btu
suz155
Hello all,
Still looking at the different B's and comparing. I live in Southern Texas and summers can be brutal. Still work full time and I can not "get away" to the mountains on a weekend trip, too far. So, the r/v staying semi cool, is important.
I did notice some r/v's have 13500btu's(most)and some have 15000btu's Does that make a difference in the temp in the vehicle or is it negligible?
Thanks
2002 Holiday Rambler Endeavor DST
Collecting memories, not things.
22 REPLIES 22
Triker33
A Coleman 13.5K PS will use less AMP's
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
Horizon170
Horizon170 wrote:
I too would suggest the 13.5K BTU, however the size of your RV comes into play.
I looked at the RV size and stick with my suggestion.
Remember that an A/C too large isn't as effective as the proper size one.
Your Generator will also thank you and as someone mentioned you can use a 15 amp circuit when at home. Just make sure the circuit is dedicated for the RV and doesn't have other house stuff plugged inside the home.
Happy travels.
EDIT------Unless the unit comes with a heat strip in the A/C I would never pay extra for it.
Marvin
2010 Coachman Freelander 22TB on a
2008 Sprinter/Freightliner chassis
1995 Geo Tracker (Toad)
Horizon170
Happy travels.
Marvin
pianotuna
Nomad III
Nomad III
Hi,
I'd go with the 13500--that way it can be run safely on a good quality 15 amp circuit. (i.e. at your home). The 15000 is just that little tiny bit harder to run.
If a heat pump is an option--I'd go with a 13500 btu unit.
Regards, Don
Golden_HVAC
How big is this RV?
I think a 13,500 Btu A/C is going to cool the small space so quickly, and will not take the time to dehumidify the air in the RV. A larger air conditioner will cool it even faster, leaving most of the humidity in the air.
I have a 30' long RV that is well insulated (as RV's go) with lots of windows, and 240 square feet of roof. I lived in Phoenix with one A/C unit when some days reached 105 and others 110. While not "Cool" inside, it was cooling the RV and reasonable inside.
So make sure that your roof is white, and get the 13,500 Btu air conditioner. If you plan a lot of winter camping, or using the RV as a extra bedroom while at home, you might consider a heat pump so you can warm the RV too.
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
suz155
I should have mentioned , I am looking at the Sprinter based B's. They, for the most part, have the 13500.
mumkin
Definitely the 15000 if you have the choice. When we read people complaining about their AC, it is people in the SW heat with a smaller unit. In fact, LTV has now switched to 15000 units for that very reason, but only in their small C units. Their B's still get 11000 ac units. I checked Roadtrek and Pleasureway sites and they seem to only use 10-11000 units too.
So, I am not sure what B's you are seeing with 13500 or 15000 ACs.
Mumkin
2021 Promaster 1500 188wb conversion
2019 Roadtrek Simplicity SRT (half Zion/half Simplicity)
2015 Roadtrek 170
2011 LTV Libero
2004 GWV Classic Supreme
Mandalay_Parr
Probably depends on the size of the B.
In warm climates I would go with the big one.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
