DanJDT's avatar
DanJDT
1988 Travel Master Pompano
Looking for any literature on a 1988 Pompano. Cant find anything on my own so I was wondering if anyone that had anything they could share that would help me a lot.
I am having an issue with the rear brakes and the trail axle.
Its a 36 foot RV.
  • Okay, I have everything bled out and fluid is in its proper location. but how does this booster line run? I am assuming it runs off of vac pressure from somewhere.
  • Still stuck and trying to get out to inspection soon. Front brakes work fine. Going to pull it back up the hill to work on it tomorrow but I need something and I haven't been able to find anything
  • I believe it's a Chevy one ton. How do I find the chassis model? 454
  • Welcome to the forum.
    What engine/chassis is under your motorhome? That's the info you need to be researching. When you know they chassis make/model, you can find the information needed to make your repairs.
  • Bump
    How does the trail axle/back axle brakes work on this model? Is there a vacuum line that controls the master cylinder?
