May-02-2018 05:01 AM
May-02-2018 04:29 PM
May-02-2018 03:33 PM
May-02-2018 03:21 PM
dougrainer wrote:
Tow Capacity has to do with the HITCH that is installed, NOT the Chassis or Powertrain. Newmar installed 5000 lb hitches. The HITCH is rated at a MAX of 5000 lbs. Later, Newmar and Monaco and others installed 10k hitches. BUT, if you increase above 5000 lbs you will have to beef up the Hitch and its mounting to the chassis frame. LOTS of Diesel owners have done that to pull loads greater than 5000 lbs. Doug
May-02-2018 02:15 PM
May-02-2018 01:29 PM
K Charles wrote:Plumber101010 wrote:mike brez wrote:K Charles wrote:
GCWR minus GVWR. There brochure says it's 324000 and 27400
I think your #s are a little off :B
I agree, the specifications I am showing is tad under 26,000 fully loaded!
That was a typo, spec says 32,400 and 27,400
May-02-2018 12:43 PM
May-02-2018 11:28 AM
May-02-2018 09:38 AM
May-02-2018 09:16 AM
May-02-2018 09:05 AM
May-02-2018 09:02 AM
Rick Jay wrote:
Sorry, I'm probably violating at least one of your rules, but what minivan has a 5,000 lb. tow rating? We may be looking for a replacement for our Odyssey in the coming years and I've yet to see any minivan with more than a 3,500 lb. tow limit, and even that is usually with only a single occupant in the van.
Why don't you just look for DP with a 10,000+ lb. tow rating? There seems to be quite a few of them around. In fact, I just checked on the 2000 Newmar Brochure and that floorplan on the Spartan Chassis has a GCWR of 37,400 and a GVWR of 27,400, so it should be able to handle 10,000 lbs.
So, I suspect if you do research (maybe you already did) on the differences between the Spartan and Freightliner chassis of that era, you might have an answer.
Well, whatever you decide, good luck in your search and decision.
Rick
May-02-2018 08:57 AM
hipower wrote:
I can't and won't get into the legalities etc., just stating my personal experience.
I have a 2003 DS (4050) 40 diesel coach. I have approximately 105,000 on it and have pulled my 2009 Chevy Silverado about 30,000 miles behind it. I don't know the weight of the truck either empty or loaded as we tow it. Sometimes it has a bunch of extra stuff in it, others it has our golf cart in it. I use a 10K rated Blue Ox tow bar and baseplate along with an auxiliary braking system. I have never beefed up the original hitch and inspect it once a year just to make sure nothing has broken or come loose.
I have never experienced any engine, transmission or other drive train issues that could be remotely attributed to towing my truck.
Advice to the OP, do what you want with this info on my personal experience.
May-02-2018 08:55 AM
May-02-2018 08:53 AM
hipower wrote:mike brez wrote:
That 300hp engine ain't going to like it
For many years we trucked freight up and down the highways with less than 200 HP. Long before the interstate highway system eliminated or bypassed some of the real grades on this country. 300 HP is not even slightly taxed by moving a motorhome and a toad down the road today unless you expect the combination to drive like a car and not a large vehicle.
