Chuck6174's avatar
Chuck6174
2010 Monaco Diplomat 42SKQ no parking lights
2010 Monaco Diplomat 42SKQ no parking lights. Could use some help locating a possible blown fuse which blew when I was replacing a bulb on the trailer I was towing. I have power to the relay R13 and fuse F66 is good. I don't have voltage to the in terminal of the relay (#30). Does anyone know where the fuse for the parking lights is located other than the F66 which is in the compartment under the driver or where I could get a wiring diagram for my My 2010 Monaco Diplomat 42SKQ? Any help would be appreciated.
  • Ivylog's avatar
    Ivylog
    I’m in the process of trying to solve the same problem on a 04 Dynasty plus the horn doesn’t work. Could not find any blown fuses front or rear.
    Will report back when I figure this out
    Found the fuse for the run lights with a 10A fuse on my 08 Navigator in the FRB. There is also a relay on the right side of the picture behind the plug with the brn-green-brn-orange wires for the parking/run lights.
  • Check the fuse panel in the rear engine compartment. Passenger side....Dennis
