Aug-01-2014 05:49 AM
Aug-02-2014 07:59 AM
Aug-02-2014 06:46 AM
luvlabs wrote:
sloman2001,
Amazing amount of incorrect information you get on these forums isn't it? I'm not sure why you think you need metal valve stems on your CRV, but you don't. The TST sensors can be screwed on to your existing valve stems without a problem - just make sure you take them off going through a car wash. If you are still not sure, call TST as they have some of the best customer service around and can advise you if you need to do anything.
Metal valve stems are normally used for high pressure applications like truck or motorhome tires. Your CRV with be in the 30 psi range and rubber is fine.
Aug-02-2014 05:08 AM
Aug-01-2014 09:38 PM
Aug-01-2014 07:39 PM
Aug-01-2014 05:43 PM
Aug-01-2014 11:42 AM
Aug-01-2014 10:24 AM
Aug-01-2014 09:47 AM
Aug-01-2014 08:45 AM
Aug-01-2014 08:44 AM
Aug-01-2014 08:21 AM
Aug-01-2014 07:26 AM
DownTheAvenue wrote:
First, you better triple check the towability of that 2014 Honda CRV. I was thinking they were no longer towable. Second, can't a capable tire shop replace the valve stems? They should be a fairly standard item.
Aug-01-2014 06:52 AM
