2014 Honda CR-V TOAD Metal Valve Stems
sloman2001
I am wanting to buy the 2014 Honda CR-V AWD for a TOAD, and my problem is that the dealer does not carry metal valve stems for the tires, it comes with the typical rubber valve stems. I called auto zone and they have no info on it so they can't order it. For those using a TPMS, where have any of you gotten the metal valve stems or does anyone know what size is needed. I haven't taken delivery of the CR-V yet, but it can't be a deal stopper, but it is puzzling. BTW, I use the TST TPMS.
Any help appreciated.
Thanks, Tom
20 REPLIES 20
racerchaser
If the only thing concerning you about the CR-V is metal valve stems I think that you are going to have the same problems with any toad. I and dozens, if not hundreds, of others have used TST TPMS sensors on toad rubber valve stems with no problems. Ignore those who muddy the water with info about the federally based monitoring systems since you need to be in your car to use it. Yes, the TST FAQ page does say it is best to use metal valve stems but if you call them I think that they will say that rubber stems are also okay. Maybe they will not but they have to consider the liability issue with any statements. Their primary customer is the truck/RV owner. The tires on these units have much longer stems. I cannot envision a situation other than something like a car wash where the typical short auto rubber stems would cause a problem.
Fox
smlranger
luvlabs wrote:
sloman2001,
Amazing amount of incorrect information you get on these forums isn't it? I'm not sure why you think you need metal valve stems on your CRV, but you don't. The TST sensors can be screwed on to your existing valve stems without a problem - just make sure you take them off going through a car wash. If you are still not sure, call TST as they have some of the best customer service around and can advise you if you need to do anything.
Metal valve stems are normally used for high pressure applications like truck or motorhome tires. Your CRV with be in the 30 psi range and rubber is fine.
Ditto on the car wash. I forgot to remove my TST sensors before getting the car washed in Myrtle Beach and the machine snapped off one of the front tire valve stems. Tire was completely flat before I exited the car wash. Also discovered that no tire store could fix it. Since the stem had the factory tire pressure sensor built in, had to take it to a Honda dealer.....$158 and two days later, I was good to go.
My 2012 CRV has metal stems. I removed the TST sensors... they were more trouble than they were worth for me.
2019 Grand Design Solitude 384GK 5th wheel. Glen Allen, VA
bshpilot
I've never changed the OE valve stems on my wrangler & i run the TST system - never had an issue and I've got no marks on my wheels to indicate any potential issue. our wrangler has at least 30k on it combined towing & driving (the only time i remove the sensors is to change the batteries).
Don R.
'04 42' Haulmark Motor Coach - 450hp/1650tq / 12 spd SmartShift
'12 Jeep Wrangler Sport (manual trans)
'17 Platinum F350 (6.7L, SRW, CC, Long bed, 4x4)
MeanderMan
I tow a 2013 CRV with the Tire Traker. The sensors are not much bigger than the valve stem caps and are no problem with the standard stems. Three years of full timing without a problem.
Happily Fulltiming Somewhere
2006 Itasca Ellipse 40FD
2013 Honda CRV
Our RV Blog
LetsRV
+1 lovlabs.
I have 2014 CRV, I use the TST system, on original valve stems, without any problems.
Read the manual and it will tell you exactly what needs to be done to tow the car with four-down. Not hard and works very well.
Due to depreciation the above opinions are now worth less than what you paid for them.
We are all good at something.....
I just happen to be a good bad example.
2016 Forest River Forester 3011DSF
Beverley_Ken
The 14 CRVs use a different type of TMPS system. It is integrated with the anti-lock braking system, (counts wheel revolutions) as opposed to the in wheel sensors. Check the CRVs owners forums to see how well that works.
That said the valve stems on the CRv are very short and should not have a problem with TST or other sensors.
Beverley and Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
Ray___June
My 2013 CRV with alloy wheels has metal valve stems from the factory.
Sold the house, retired, and full timing. 15 years of dreams come true!
2015 Itasca 33C, Black Garnet
2013 Honda CRV EXL toad
Roadmaster Sterling all terrain tow bar
Roadmaster Tow Shield
Roadmaster Guardian
SMI "Stay-in-Play" Brake system
ISL "Toad Charge"
tropical_ron
? Extended towing
If you tow more than eight hours in one day, you should repeat the โ€œbefore towing your vehicle procedureโ€ at least every eight hours. You also need to perform the following procedure to prevent the battery from running down.
1. Remove the 7.5 A accessory radio fuse.
This fuse is located in the interior fuse box.
2 Interior Fuse Box P. 338
2. Store the fuse in a safe place so you do not
lose it.
u Make sure to reinstall the fuse before
you start driving your vehicle.
The above data comes from 2014 CR-V owners manual. Check with dealer and have them show you where this fuse is located...and have them point it out. My guess is that it is very difficult to access. In our 2010 CR-V we had a remote fuse switch installed and that fixed our dead battery issues. By the way, 4-5 hours of towing was enough to cause problems.
Best of luck.
2007 National Tropical T370 LX CAT-350
2010 Honda CRV awd
Blue Ox Baseplate
SMI aux. brake
Born_To_Travel
This is what the TST website says.. Do I need special valve stems?
No, you do not need special valve stems, but you do need commonly available metal valve stems.
The added weight of the sensor on a rubber valve stem could cause problems that will be avoided by using metal valve stems.
Most motorhomes and commercial transport vehicles come equipped with metal valve stems. If you do need metal valve stems, they are not expensive; a recent customer had 6 valve stems replaced on a 30โ€™ gooseneck racing trailer for $36. They are available and can be quickly installed by any tire dealer.
What is the device with the steel handle I see in the pictures of your systems?
Our sensors are theft resistant because the outer sensor shell spins freely on the sensor so that it can not be removed by hand. The sensors must be installed and removed with the handled wrench you see in the pictures. We include 2 of these wrenches with each system
You can find them at any tire only business or you can get them here.. http://www.amazon.com/s/ref=sr_nr_n_0?rh=n%3A15684181%2Cn%3A15706721%2Ck%3Ametal+valve+stem&keywords...
luvlabs
sloman2001,
2017 Winnebago Navion 24V
2014 Tiffin Phaeton 36GH (sold)
2012 Tiffin Allegro 32CA (traded)
2012 Honda Fit
robatthelake
There should be an aftermarket wireless monitor that integrates the Factory built in system ! I'm sure that some engineer is working on a workable system.
It would need to be a Plug And Play module that transmits the Warning Signal to the Motorhome .
I wonder if a Wireless Camera could be used in the meanwhile that shows the Tow Cars Dash on a screen . Naturally there would need to be a power source which doesn't run down the Toads Battery.
Rob & Jean
98 Dutch Star Diesel Pusher ..07 Honda CRV AWD
Ivylog
Instead of replacing the stems, find a rubber hose that slips on the stem and is big enough to touch the rim. This will keep the stem from moving outward.
Upgraded with a 08 HR Navigator 45โ€™...
cKarlGo
DownTheAvenue wrote:
First, you better triple check the towability of that 2014 Honda CRV. I was thinking they were no longer towable. Second, can't a capable tire shop replace the valve stems? They should be a fairly standard item.
2014s are towable. 2015s are not, I believe.
k.
2014 Itasca Suncruiser 38Q
2014 Honda CR-V
2007 Black Lab/Pitt Bull mix named Harley
Mandalay_Parr
I run external TPS on my rubber valve stems for 10 years with no problems.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
