Well, I drove a W-22 8.1 37'7" motor home with towed till the oil was lost (suddenly) and the engine blew.
I really liked it, engine had plenty of power, and GM engines are nice. The Allison transmission is hard to beat. I mean, if you ask which is the better engine, Ford or GM, both have supporters and you will get a lot of "Discussion".
IF you ask who makes the best transmission even FORD says it is ALLISON, (Their latest automatic is described as "The Answer to the Allison" by Ford,, In this case I'd listen to Ford).
The Brakes,, if the recall has been done the issue is solved, there was also a fuel clip recall you need to check to see if they were done. That is all.
