88 Limited Generator Service
jmerritt
I need to replace/repair the exhaust manifold on my Onan NHE genset in our 88 Limited. Is there a way to swing the genset down or does it have to be removed to get at the backside of the engine? I have looked at the compartment and there is an angle bracket at the rear that would appear to support the swing down idea but I thought it best to ask to see if anybody knows for sure.
Thx for your help
John
2004 Holiday Rambler Presidential 5th Wheel 32'
5 REPLIES 5
wildmanbaker
Wow! $400, I believe it could have been repaired at half that price, but its done now and working, right.
Wildmanbaker
jmerritt
Already ordered and received replacement Onan parts for the generator. Manifold, gaskets, etc., totaled about $400. Generator is back in and running fine and quiet.
wildmanbaker
It can be welded, if you not a welder, or know someone who is a welder, it may cost as much as a replacement manifold.
Wildmanbaker
bfast54
Ummmmmm,....Have you tried contacting Onan......should be a 800,or onan.com.....somewhere?????
2000 Ford SuperDuty F-350 Powerstroke,Dually.C.C.,.The Tow Monster
2005 Open Road 357RLDS
Prodigy Brake Controller:B
Honda EU3000is Generator
Raytek ,,Garmin 7735/GPS
Doran Mfg-RV360-TPMS
B&W/Companion
Rally's attended so far-21
My Blog
Good Sam Member
jmerritt
Had the generator removed and found that the exhaust manifold was broken in half due to a blown tag axle tire that hit the exhaust pipe right behind it. Genset had to be lowered using a floor jack and removing the support beams under the genset.
